Abed_AL-R's avatar
Abed_AL-R
Jul 06, 2020
APM | Native RDP SSO
Hello guys
We switcheed from ActiveX RDP to Native RDP
Everything before worked fine with ActiveX RDP including SSO, but today we have to switch to native in order to upgrade to v14 or later
Currently we're using v13.1.1.5 and we're willing to upgrade to v15 , there no activex is supported anymore.
Anyhow , the RDP connection works fine with native but the SSO is not getting mapped.
Is there something special with native RDP we need to setup
I followed many KBs and articles in devcentral but no luck ..
I did also the SSO Credential mapping although I know we don't need that
we're using : session.ldap.last.attr.userPrincipalName and session.logon.last.password
screenshot bellow:
When I look at CLI APM logs I see the following:
{11e.S} An exception is thrown: Net:1: Connection was closed
According to K08943176 they're saying to check the username / password or domain variables
But I think those variables are configured properly
regarding the domain variable I set variable assignment in VPE and still nothing works ..
again , it is working fine with activex .. (without using domain variable, only using session.ldap.last.attr.sAMAccountName as the username source)
v13.1.1.5
  • we found the issue
    https://support.f5.com/csp/article/K08943176
    according to this article Native RDP is not accepting combining username and domain in the same field.
    We thought at first that we can use this usernme source as activex: session.ldap.last.attr.sAMAccountName
    But no, we created variable assignment with static domain name and configured in the domain souce: session.logon.last.domain
    And now it is working fine
