06-Nov-2020 05:31
APM Guided configuration is missing from my BigIP trial VE.
Any idea what can be the problem?
Solved! Go to Solution.
14-Nov-2020 14:45
Hello Ricardo.
Check this out.
https://support.f5.com/csp/article/K07562814
Regards,
Dario.
11-Nov-2020 13:39
Hello Ricardo.
What do mean by missing?
Trail versions have options for guided config, but maybe you are facing some kind of bug. Check this out:
https://cdn.f5.com/product/bugtracker/ID677964.html
Regards,
Dario.
11-Nov-2020 15:34
It's really missing.
Not showing here, on the gui, anywhere.
11-Nov-2020 22:57
What release are you running?
Take into account that guided config is not available in all releases.
https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/product/relnote-bigip-14-1-0.html#rn_apm_1410_new
Regards,
Dario.
14-Nov-2020 12:22
I'm running v16. But v15 also does not show the APM guided config.
14-Nov-2020 14:45
Hello Ricardo.
Check this out.
Regards,
Dario.
15-Nov-2020 03:57
Ok.
That explains it.
Thanks.
15-Nov-2020 09:18
Hello Ricardo.
Please, don't forget to mark my answer as 'the best' to help other people to find it ;-).
Regards,
Dario.
