chris100_263517's avatar
chris100_263517
May 15, 2016
APM CRLDP - verify signature
Hello,
I'm using machine cert checker with crldp for http using the method described in this post.
https://devcentral.f5.com/questions/machine-certificate-revocation-checks
Everything appears to work as expected except I get a failure when the 'verify signature' is checked. I assume this is the signature on the CRL? but this is issued by the same CA as the machine cert and there doesn't appear to be any configuration options apart from the checkbox, any ideas what I'm missing?
thankyou
  • Hi
    Have you got the "Use issuer" option unselected? I just verified on 12.1 for the check of user client certificate and it works ok (only the option "verify signature" is enabled, server connection=no server)
    Alex
  • Do you have an update for this issue? I have the same or very similar issue. If you have resolved, can you tell us how?
