Technical Forum
APM Accept Encoding - f5 clears options
Bingo
Have a v 13.1 f5 APM - the servers see:
Dont need F5 to do the compression, just pass on the header indicating that encoding is supported.
BUT the Accept-Encoding is blank coming from the F5. I ran a request and pulled the headers for that request from the browser and then checked what was seen coming into the app.
Browser sent:
-          Accept-Encoding: gzip, deflate, br
F5 sent:
-          Accept-Encoding:
Do you need an http compression profile saying disabled.no to the options so that the Encoding option is retained ?
seems to be making the connections slow
thanks
0 REPLIES 0
