20-Oct-2023 01:46 - edited 20-Oct-2023 01:49
Looking to try running it under Proxmox. Particularly from those F5 people who would know... @Leslie_Hubertus Let me know of any deal breakers in that regard. Since the CM provisions devices it may not like Proxmox and I may be better off staying with VMware ESXi 7.5?
20-Oct-2023 04:11
i was able to install BigIP-Next CM on proxmox which also runs. BigIP Next Instances i could not setup yet (created locally on a seperate VM), because i cant login via admin/admin the first time.
You need 16GB of RAM for the BigIP-Next CM VM otherwise the setup will fail.
20-Oct-2023 13:26
Hi @sraue intriguing...I haven't tried CM on proxmox because KVM isn't yet officially supported for CM, but I'm glad you got it working! Might try the same...
20-Oct-2023 13:25
proxmox is just a KVM wrapper so I'm not sure why that wouldn't work, I have the next instance running in my ubuntu 22.04 LTS KVM environment. Quick note though that is not in the public docs yet...you have to use the i440FX chipset when setting up your VM, the Q35 chipset won't work.
