Technical Forum
adding more CPUs in VCMP guest active standby device
herdi
i want to add more cpu on vcmp guests
1. backup config
2. makesure all guest on vcmp host standby
3. change to configure all guests
4. add cpu
5. change configure to deployed state
should i forced offline mode on standby guest and change automatic sync to manual to prefent something on active guests
thanks
2 REPLIES 2
Hi
this is viprion hardware, i have 2 viprion with 4 blade each host have vcmp guestes and running active standby guestes, i want to add core cpu on guest
my concern is should  i forced offline on guest standby and change sync group to manual to prevent on active guest
thanks
Hey - that first reply was ChatGPT junk that was then edited to be SPAM afterwards. Sorry about that. I'll pin your question to the top of the forum since it has now been kicked off the "no-replies" list.
Lief
