Technical Forum
adding a new field for comments. is it possible?
spark1985_38753
hi all, i want to know if its possible to add another description (or a comments/notes field) for us to put ticket numbers/change references in? The description field when adding is already in use. we are running LTM 13.1.07 due to upgrade to 14.1.02 soon but its so we can track who owns each VIP etc
Thanks in advance
1 REPLY 1
Kai_Wilke
MVP
MVP
Hi Spark1985,
you can't add additional configuration object fields. But you could organize the description field value as a list-item...
root@(f501)(cfg-sync Standalone)(Active)(/Common)(tmos) modify ltm virtual Test description "Some blah blah" root@(f501)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm virtual Test description ltm virtual Test { description "Some blah blah" } root@(f501)(cfg-sync Standalone)(Active)(/Common)(tmos) modify ltm virtual Test description "Some blah blah | TicketID: 1337" root@(f501)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm virtual Test description ltm virtual Test { description "Some blah blah | TicketID: 1337" } root@(f501)(cfg-sync Standalone)(Active)(/Common)(tmos)
Cheers, Kai
