Technical Forum
Active-Active HA setup with F5 i2600 and F5 i2800
F5Team
Altocumulus
Altocumulus
We have 2 standalone F5 devices, F5 i2600 and F5 i2800
It is possible to configure Active-Active HA setup using F5 i2600 and F5 i2800
https://my.f5.com/manage/s/article/K35614055
The article below suggests that there's an option of increase the capabilities of i2600 by applying an optional module.
4 REPLIES 4
Paulius
MVP
MVP
@F5Team I have never had the opportunity to test this but at face value it seems like it could work because the devices are almost identical with minor differences. Now I do know that F5 hasn't released an article on doing cross platform HA so I doubt it will work but it's worth a shot. Just make sure you backup the configuration of each device along with the master-key of each device if by chance something goes wrong and things no longer work. UCS backup of each device, not just going into the device and doing a "show running-config" for a backup.
The article below states that you can have HA between different hardware platforms or between virtual and hardware platforms, I and my colleagues have done this several times in the past but I couldn't remember if I have done it for an Active/Active scenario, but I think it should work though.
BIG-IP redundant configuration hardware and software parity requirements (f5.com)
LiefZimmerman
Community Manager
Community Manager
@F5Team - If your post was solved it would be helpful to the community to select *Accept As Solution*.
This helps future readers find answers more quickly and confirms the efforts of those who helped.
Thanks for being part of our community.
Lief
@LiefZimmerman Still we haven't tried to form HA , We will confirm once it's establish.
Hopefully it will work
