Access applications through SSO without login page
Cleo1
Altostratus
Altostratus
Hi all,
I have a requirement where, user logs into his/her PC within the network by applying its credentials which are synced by active directory, should have access to "x" number of applications through SSO. Application authentication is synced with the same active directory, so they should not be getting separate login page to access the applications because user has already authenticated once when logging into its PC. Client has BIG-IP APM into its environment. Can anyone help me out with this requirement.
Thanks in advance!!!
1 REPLY 1
Yoann_Le_Corvi1
Cumulonimbus
Cumulonimbus
The x application would not support Kerberos by any chance ? That would be the smartest way to fulfill your requirements.
Yoann
