17-May-2023 01:40 - edited 17-May-2023 02:19
Hello,
I am trying to set up Site to Site VPN between F5 and PA but can't get it to work.
Here is my structure :
Here is my PA setting :
Here is my F5 setting :
Virtual Server has created a Forwaring IP
Am I missing something?
or is the setting wrong?
Any help is appreciate.
17-May-2023 05:40
@Michaelyang Do you have any debug logs on either side of this tunnel? Ideally if you could provide debug logs from both sides that would be helpful in narrowing down the issue on this.
17-May-2023 07:18
17-May-2023 08:17
@Michaelyang That should be the location that logs for IPsec tunnels are sent.
29-May-2023 06:37
or /var/log/ipsec.log
did you find anything there?
30-May-2023 03:07
Hi @boneyard ,
Nothing...
30-May-2023 08:11
both are empty?
