1qaz's avatar
1qaz
Jun 04, 2020
a problem about get source address through X-forward-for
I have a question, my VS is useing snat, with X-forward-for in http_profile, but I see some source addresses are not obtained? I also noticed that all the lost source addresses are okhttp,why?
Thanks for any help!
  • OkHttp is an HTTP client that's efficient by default: ... If your service has multiple IP addresses OkHttp will attempt alternate addresses if the first connect fails.
    Could you please share what kind of VS config is there.
    Please run this command
    list ltm virtual <name-of-VS> details
    • 1qaz's avatar
      1qaz
      thanks to Sachin-Garg,
      list ltm virtual VS_CRM_NLFK_9080
      ltm virtual VS_CRM_NLFK_9080 {
        destination 134.175.22.206:glrpc
        ip-protocol tcp
        mask 255.255.255.255
        pool Pool_CRM_NLFK_9080
        profiles {
          http_yuanIP { }
          tcp { }
        source 0.0.0.0/0
        source-address-translation {
          type automap
        vs-index 131
    1. You said , you are suing SNAT but i can see its Automap(which will use the self ip of your internal interface to source nat the source IP address), you can also use any static IP instead of Automap in case you want to use that IP to be used for SNAT Purpose. Just in case but this one also ok if it is not causing any issue,
    2.
    3. Can you please share the details of your http profile by running following commands in tmsh mode
    4.
    5. list ltm profile http http_yuanIP details
    6.
    7. for checking the connection details on your VIP
    8.
    9. show sys connection | grep 134.175.22.206
    Best Regards
    Sachin Garg
    • 1qaz's avatar
      1qaz
      thanks,I noticed that only okhttp has no source address, but okhttp does not always appear
      ltm profile http http_yuanIP {
        app-service none
        defaults-from http
        insert-xforwarded-for enabled
      106.19.5.121:50700   134.175.22.206:9091  106.19.5.121:50700   134.176.1.228:9091  tcp  63  (tmm: 3) none
      106.16.132.94:41796  134.175.22.206:9091  106.16.132.94:41796  134.176.1.228:9091  tcp  38  (tmm: 3) none
      106.18.147.4:12642   134.175.22.206:9080  134.176.1.196:16260  134.176.1.225:9090  tcp  58  (tmm: 2) none
      106.17.200.187:30317  134.175.22.206:9080  134.176.1.196:49075  134.176.1.226:9090   tcp  64  (tmm: 1) none
      223.150.23.248:15461  134.175.22.206:9080  134.176.1.196:58407  134.176.1.226:9090   tcp  92  (tmm: 1) none
      106.19.3.31:15369   134.175.22.206:9080  134.176.1.196:35483  134.176.1.226:9090   tcp  137  (tmm: 1) none
      220.202.118.3:21709  134.175.22.206:9080  134.176.1.196:60991  134.176.1.225:9090   tcp  250  (tmm: 1) none
      106.16.162.55:51031  134.175.22.206:9091  106.16.162.55:51031  134.176.1.227:9091   tcp 31  (tmm: 0) none
      106.16.156.197:62938  134.175.22.206:9080  134.176.1.196:54220  134.176.1.225:9090  tcp  35  (tmm: 2) none
      58.45.29.238:26466   134.175.22.206:9080  134.176.1.196:24216  134.176.1.226:9090  tcp  284  (tmm: 2) none
      106.16.150.173:43584  134.175.22.206:9091  106.16.150.173:43584  134.176.1.227:9091   tcp  11  (tmm: 3) none
      106.19.21.235:56092  134.175.22.206:9091  106.19.21.235:56092  134.176.1.227:9091   tcp  48  (tmm: 3) none
      223.152.95.189:37259  134.175.22.206:9080  134.176.1.196:29241  134.176.1.225:9090   tcp  67  (tmm: 3) none
      118.251.19.94:49046  134.175.22.206:9091  118.251.19.94:49046  134.176.1.227:9091  tcp  55  (tmm: 1) none
  • As you can see the
    1st Column = Real Source IP:port
    2nd Column = VIP:port
    3rd Column = SNAT Source IP:port using Self IP of Internal Interface
    4th Column = Pool Member:port
    Here I could see that your another VIP 134.175.22.206:9091 The client original address is visible to the backend pool member
    1st column is same to 3rd column
    But for the another VIP 134.175.22.206:9080 the 1st column IP is changing with your F5 Self IP of Internal Interface or SNAT IP 134.176.1.196 in the 3rd Column:
    Can you please compare the 2 VIPs config and share:
    VIP 134.175.22.206:9091 - Client IP address is visible to the pool member
    VIP 134.175.22.206:9080 - Client IP address is NOT visible to the pool member
  • Here I could see that your another VIP 134.175.22.206:9091 The client original address is visible to the backend pool member
    In that case your pool member 134.176.1.227:9091 will response directly to the Client IP 106.19.21.235:56092 bypassing F5 load balancer , are you seeing any asymmetric routing issue on this VIPs
    • 1qaz's avatar
      1qaz
      thanks,
      VIP 134.175.22.206:9091 don't use SNAT,no automap
  • So do you feel your issue resolved/explained or would you like me to look into anything further. Kindly let me know.
    • 1qaz's avatar
      1qaz
      Thank you very much for your help, my colleague suggested that I cancel the snat on VS 134.175.22.206:9080 to solve this problem, and I am considering accepting his suggestion
    • 1qaz's avatar
      1qaz
      thanks to Sachin-Garg,I decided to cancel SNAT to get the source address because SNAT is not necessary, thank you for your help, thanks again!
