Gajji's avatar
Gajji
Feb 21, 2021
30+ different URL to be monitored(api call) - in http monitor is it feasible
30+ different URL to be monitored(API/Service HealthCheck monitor ) - in http monitor is it feasible
so, once either of the API is down on that backend it will direct it to other available backend where that API is available.
  • Can you elaborate more on your requirement.
    If there's an endpoint which is unhealthy, automatically it will be marked unavailable & remaining endpoints in the cluster will answer the calls.
    • Gajji's avatar
      Gajji
      Yes but the question is , can i monitor through http monitor such that where
      we can monitor 30+ url on server(pool member) and if out of 30+ url one is not there .....can the traffic goes to other pool member?
      • jaikumar_f5's avatar
        jaikumar_f5
        Icon for Noctilucent rankNoctilucent
        Mmm thats 30 end points to be monitored for a given server.
        Yes http monitor with and operation will do it. But that would be like creating 30 monitor (each 1 for each endpoint), which is not a right way to implement.
        I'd explore the external monitor for this, just a single monitor where I'd put if condition to check all 30 end points. Since it's multiple end points, I don't think you'd be really looking for a particular keyword, but would go with http status code.
