API rest - monitor at pool settings
Hello,
when I add monitor to pool via Rest API it works fine untill I try to set "Availability requirement" to "At least 1".
In API it's done with prefix "min 1 of" (https://clouddocs.f5.com/api/icontrol-rest/APIRef_tm_ltm_pool.html)
You can specify a single monitor, multiple monitors “http and https”, or a “min” rule, “min 1 of { http https }”.
But when I try it, I get 400 and such message: "01070022:3: The monitor template { was not found.",
I use version v14.1.4.
Can you help me with this? Thanks
Zdenek
If you take off the curly braces it should work (tested with TMOS v15.1.3.1).
Please try:
curl -svk -u admin: 'https://localhost/mgmt/tm/ltm/pool/~Common~pool_monitor_test' -H 'Content-Type: application/json' -X PATCH -d '{"monitor": "min 1 of monitor_https_A monitor_https_B"}' | jqTo remove existing monitors:
curl -svk -u admin: 'https://localhost/mgmt/tm/ltm/pool/~Common~pool_monitor_test' -H 'Content-Type: application/json' -X PATCH -d '{"monitor": "none"}' | jq
- StephanManthey
Nacreous
Please try:
curl -svk -u admin: 'https://localhost/mgmt/tm/ltm/pool/~Common~pool_monitor_test' -H 'Content-Type: application/json' -X PATCH -d '{"monitor": "none"}' | jq- Zdenda
Cirrus
Thank you, nice easter egg 🙂
