08-Apr-2021 01:58
hi experts,
just want to check, have anyone tried to enable 2 way ssl from which F5 is the client?
We know enabling the 2 way on the client ssl profile, this method F5 is the one authenticating client.
How about when it is facing the server? Server will enable 2 way ssl, F5 will be the client. Is this possible?
TIA
Solved! Go to Solution.
08-Apr-2021 12:28
Hi TIA,
yes, this is possible. In my loadbalancing pool, I have two nginx servers with the following config:
# HTTPS virtual server
server {
listen 8443 ssl;
server_name _;
ssl_certificate /etc/ssl/certs/nginx.crt;
ssl_certificate_key /etc/ssl/private/nginx.key;
ssl_client_certificate /etc/ssl/certs/My_Domain_Issuing_CA.crt;
And in the Server SSL Profile I configured the following.
ltm profile server-ssl pr_serverssl_mtls {
app-service none
cert ffive01.mydomain.com
defaults-from pr_serverssl
key ffive01.mydomain.com
The cert is issued by My_Domain_Issuing_CA. That's all it needs.
KR
Daniel
08-Apr-2021 12:28
Hi TIA,
server {
listen 8443 ssl;
server_name _;
app-service none
KR
Daniel
14-Apr-2021 01:26
thanks Daniel. This helps a lot!
