16.0.1 LTM OVA Login
LH
Hi folks,
Apologies for the simple question.
I've downloaded the BIG-IP LTM 16.0.1-0.0.3 ova and installed it on ESXi 7. It's there no problems, I can log into the cli with root/default, give it a management address that I can browse to, but I can't log into the gui with admin/admin.
I've tried resetting the admin password with
tmsh modify auth user admin prompt-for-password
and
save sys config
but I still can't log in and get auth failed in the secure log.
What am I missing?!?
Best, Leigh
1 ACCEPTED SOLUTION
LH
I've sorted it, I needed to reset the password with
passwd admin
From the standard cli, it got me in then.
Hope this helps someone in the future.
Best, Leigh
1 REPLY 1
LH
passwd admin
Best, Leigh
