Chris1269's avatar
Chris1269
Jan 07, 2021
1 FastL4 VIP, 2 pools, ratio loadbalancing and 2 src persist profiles.
Hi all,
I would like to know if this is possible as I can't see a clean way of doing it.
What we need:
1 FastL4 VIP
Pool 1: 90% of connections use
Node 1
Node 2
src address persistence profile: 3600 (client IP x persists to node 1 or 2 for 3600 seconds)
Pool 2: 10% of connections use
Node 3
Node 4
src address persistence profile: 1800 (client IP x persists to node 3 or 4 for 1800seconds)
  • Mmm, haven't tested it, try this logic & let us know,
    where, 90_pool will have your node 1 & 2, & 10_pool will have node 3 & 4.
    Using the random operator & multiplying it with 100, so we can get a whole number ranging 1 - 100.
    Its same like ratio load balancing. But not exactly. But I hope the results would be similar.
    when CLIENT_ACCEPTED {
    	set random [expr int(rand()*100)]
    	if { $random > 10 } {
    	pool 90_pool
    	persist source_addr 255.255.255.255 3600
    	pool 10_pool
    	persist source_addr 255.255.255.255 1800
