on 08-Apr-2014 21:18
Get the latest updates on how F5 mitigates HeartbleedGet the latest updates on how F5 mitigates Heartbleed
The Heartbleed attack in OpenSSL 1.0.1 and beyond allows an attacker to get up to 64k of process data from a TLS heartbeat response. The 64k of data will quite often contain sensitive information such as keys or passwords. There are quite a few exploits in the wild already for this attack.
F5 has analyzed this attack and we are pleased to say that BIG-IP data traffic using an SSL profile with default ciphers is not vulnerable to this attack. BIG-IP SSL profiles terminate the SSL traffic on the BIG-IP, so the malicious heartbeat never gets to your webservers. TLS heartbeats are not enabled on current versions of BIG-IP, so any virtual server protected by an SSL profile is not vulnerable.
However, if you are not using the SSL termination capabilities of the BIG-IP, then the attack will pass directly through the BIG-IP and to the webservers. You may be vulnerable depending on the webservers you use.
BIG-IP versions 11.5.0 and 11.5.1 do use OpenSSL 1.0.1 for the management GUI and are vulnerable to the attack. Versions of BIG-IP older than 11.5 are not vulnerable.
F5 encourages using a private management network that is not connected to the internet.
A hotfix is available for the management GUI.
See the AskF5 solution for more information.
If you are using a simple load balancing virtual server without an SSL profile, then the traffic is passing directly to your webservers.
My great F5 colleagues and I have written an iRule that mitigates this vulnerability when the client sends a heartbeat. Since we haven't seen a valid client that sends heartbearts, we like this solution. If you have clients that do send valid heartbeats, then we have an iRule that watches for large heartbeat responses and kills the connection before they are sent to the client.
https://tstdmzdevcentral.olympus.f5net.com/questions/edge-client-and-cve-2014-0160-heartbleed
"However, if you are not using the SSL termination capabilities of the BIG-IP, then the attack will pass directly through the BIG-IP and to the webservers. You may be vulnerable depending on the webservers you use."
Are you talking about anyone that is not using the built-in ssl profiles at all (meaning they are not even using a VIP), or do you mean anyone that is using the ssl profiles but simply does not terminate it there and reencrypts the traffic to then send on to the destination server?
The client components will be patched for sure; but don't slow down your mitigation tasks on your servers while hunting and fixing clients that use the vulnerable OpenSSL library...
reviews of interest to a reference source for http://jualspreiantiair.com
