Technical Articles
F5 SMEs share good practice.
Payal_S
Legacy Employee
Legacy Employee
F5 has been actively developing Ansible modules that help in deploying an application on the BIG-IP. For a list of candidate modules for Ansible 2.4 release refer to the Github link. These modules can be used to configure any BIG-IP (physical/virtual) in any environment (Public/Private or Hybrid cloud)
Before we can use the BIG-IP to deploy an application, we need to spin up a virtual edition of the BIG. Let’s look at some ways to spin up a BIG-IP in the Public and Private cloud
Private cloud
Create a BIG-IP guest VM through VMware vSphere
For more details on the ansible module refer to Ansible documentation
Pre-condition: On the VMware a template of the BIG-IP image has been created
Example Playbook:
- name: Create VMware guest
  hosts: localhost
  connection: local
  become: true
  tasks:
  - name: Deploy BIG-IP VE
    vsphere_guest:
      vcenter_hostname: 10.192.73.100
//vCenter hostname or IP address
      esxi:
        datacenter: F5 BD Lab
//Datacenter name
        hostname: 10.192.73.22
//esxi hostname or IP address
      username: root
//vCenter username
      password: *****
//vCenter password
      guest: “BIGIP-VM”
//Name of the BIG-IP to be created
      from_template: yes
      template_src: "BIG-IP VE 12.1.2.0.0.249-Template"
//Name of the template
Spin up a BIG-IP VM in VMWARE using govc
For more details on the govc refer to govc github and vmware github
Pre-condition: govc has been installed on the ansible host
Example Playbook:
  hosts: localhost
  connection: local
  tasks:
  - name: Import OVA and deploy BIG-IP VM
    command: "/usr/local/bin/govc import.ova -name=newVM  BIGIP005 /tmp/BIGIP-12.1.2.0.0.249.LTM-scsi.ova"
//Command to import the BIG-IP ova file
    environment:
     GOVC_HOST: "10.192.73.100"
     GOVC_URL: "https://10.192.73.100/sdk"
     GOVC_USERNAME: "root"
//vCenter username
     GOVC_PASSWORD: "*******"
//vCenter password
     GOVC_INSECURE: "1"
     GOVC_DATACENTER: "F5 BD Lab"
//Datacenter name
     GOVC_DATASTORE: "datastore1 (5)"
//Datastore on where to store the ova file
     GOVC_RESOURCE_POOL: "Testing"
//Resource pool to use
  - name: Power on the VM
    command: "/usr/local/bin/govc vm.power -on newVM-BIGIP005"
    environment:
     GOVC_PASSWORD: "vmware"
     GOVC_INSECURE: "1"
Public Cloud
Spin up a BIG-IP using cloud formation templates in AWS
For more details on the BIG-IP cloud formation templates, refer to the following Github Page
Pre-condition: Cloud formation JSON template has been downloaded to the Ansible host
Example Playbook:
- name: Launch BIG-IP CFT in AWS
  hosts: localhost
  gather_facts: false
  tasks:
    cloudformation:
     aws_access_key: "******************"
//AWS access key
     aws_secret_key: "******************"
//AWS secret key
     stack_name: "StandaloneBIGIP-1nic-experimental-Ansible"
     state: "present"
     region: "us-west-2"
     disable_rollback: true
     template: "standalone-hourly-1nic-experimental.json"
//JSON blob for the CFT
     template_parameters:
//template parameters
      availabilityZone1: "us-west-2a"
      sshKey: "bigip-test"
     validate_certs : false
    register: stack
  - name: Get facts(IP-address) from a cloud formation stack
    cloudformation_facts:
     aws_access_key: "*****************"
     aws_secret_key: "*****************"
     region: "us-west-2"
    register: bigip_ip_address
  - set_fact:
//Extract the BIG-IP MGMT IP address
     ip_address: "{{ bigip_ip_address['ansible_facts']['cloudformation']['StandaloneBIGIP-1nic-experimental-Ansible']['stack_outputs']['Bigip1subnet1Az1SelfEipAddress']}}"
  - copy:
//Copy the BIG-IP MGMT IP address to a file
     content: "bigip_ip_address: {{ ip_address}}"
     dest: "aws_var_file.yaml"
//Copied IP address can be be referenced from file
     mode: 0644
Above mentioned are few ways to spin up a BIG-IP Virtual edition in your private/public cloud environment. Once the BIG-IP is installed then use the F5 ansible modules to deploy the application on the BIG-IP.
Refer to DevCentral article to learn more about ansible roles and how we can use roles to onboard and network a BIG-IP.
Included is a simple playbook that you can download and run against the BIG-IP.
- name: Onboarding BIG-IP
  hosts: bigip
//bigip variable should be present in the ansible inventory file
  gather_facts: false
  tasks:
  - name: Configure NTP server on BIG-IP
    bigip_device_ntp:
      server: "<bigip_ip_address>"
      user: "admin"
      password: "admin"
      ntp_servers: "172.2.1.1"
      validate_certs: False
    delegate_to: localhost
  - name: Configure BIG-IP hostname
    bigip_hostname:
      user: "admin"
      password: "admin"
      hostname: "bigip1.local.com"
  - name: Manage SSHD setting on BIG-IP
    bigip_device_sshd:
      user: "admin"
      password: "admin"
      banner: "enabled"
      banner_text: "Welcome- CLI username/password to login "
  - name: Manage BIG-IP DNS settings
    bigip_device_dns:
     user: "admin"
     password: "admin"
     name_servers: "172.2.1.1"
     search: "localhost"
     ip_version: "4"
For more information on BIG-IP ansible playbooks visit the following github link
Comments
KernelPanic
What are the various software compatibility dependencies for getting ansible f5 to work?
ManiGadde
F5 Employee
F5 Employee
@kernelPanic bigsuds & f5sdk
pip install bigsuds
pip install f5-sdk
for more details - including solution overview & technical White-paper:
Version history
Last update:
‎13-Jun-2017 04:45
Updated by:
Contributors
