Technical Articles
F5 SMEs share good practice.
JRahm
Community Manager
Community Manager
How many times have you had to log in to BIG-IP, copy/paste the tcpdump commands in, look at the file name, scp the file down or away, then rinse/repeat with other key files or re-capture something because you got the syntax wrong? I wanted to see how far I could take automation with efforts like this. On Last Week's episode of The Core, I walked through a proof of concept I built that does the following:
  1. Prompts the user for the virtual server under test, the client IP where test traffic will come from, and the support case number this traffic is being collected for. I will refactor the code in the future to make some of this optional via command-line flags.
  2. Creates the appropriate iRule from K12783074, uploads it, and applies it to the specified virtual server.
  3. Updates a tcpdump string as appropriate to the specified virtual server, the case number, and the current date, and starts tcpdump, at which point the test traffic can be executed to reproduce the issue.
  4. Stops tcpdump.
  5. Removes the iRule that was uploaded from the specified virtual server and deletes it.
  6. Creates a TLS key file using the appropriate commands from K12783074.
  7. Creates a qkview archive.
  8. Downloads all three files created in the process, then deletes them from the BIG-IP.
The code for this proof of concept is here on GitHub. This was prep work to begin experimenting with pyshark, scapy, and other tools to programmatically handle a lot of the "first steps" of packet analysis. Currently on the roadmap:
  • Utility to decrypt downloaded BIG-IP captures
  • Utility to match and visualize clientside/serverside BIG-IP flows using f5ethtrailer details
  • Utility to isolate SIP/RTP flows
  • APM flow clarity, issue isolation
What would YOU do programmatically with packet captures if you could? Drop a comment below, add an idea to the issues log on GitHub, or fork the project and join me!
Comments
I have already scripted a utility here to automatically extract the pre master secrets from a tcpdump with enabled f5 sslprovider. The pre master secret file can then be used with whireshark to do the decrpytion. Decryption works with all ssl versions including tls 1.3 any any number of tcp streams.
If there is any interesst, I can share it with the community.
JRahm
Community Manager
Community Manager
Hi @Juergen_Mang, would love to see how you're scripting the extraction of the secrets!
JRahm
Community Manager
Community Manager
actually, found your codeshare entry, nevermind! Will talk about this on the stream tomorrow.
Which stream?
PSilva
Legacy Employee
Legacy Employee
Today at 11:00AM Pacific Time: https://youtube.com/live/eexz9hnzNU0?feature=share
Version history
Last update:
‎25-Apr-2022 11:07
Updated by:
Contributors
