Technical Articles
F5 SMEs share good practice.
JRahm
Community Manager
Community Manager
What could you do with your code in 20 Lines or Less?
That's the question we like to ask from, for, and of (feel free to insert your favorite preposition here) the DevCentral community, and every time we do, we go looking to find cool new examples that show just how flexible and powerful iRules can be without getting in over your head. Thus was born the 20LoL (20 Lines or Less) series many moons ago. Over the years we've highlighted hundreds of iRules examples, all of which do downright cool things in less than 21 lines of code.
iRule to Stop SSLv3 Connections
https://devcentral.f5.com/s/articles/irule-to-stop-sslv3-connections
This iRule is pertinent for protecting your back end servers from POODLE attacks for ssl traffic delivered through but not terminated on the BIG-IP. As usual, Jeff Costlow is all over these various ssl vulnerabilities.
when SERVER_CONNECTED {
  set Debug 1
  set Collect_Len 3
  TCP::collect $Collect_Len
when SERVER_DATA {
  set Buf_Len [TCP::offset]
  if { $Buf_Len < 3 } {
    incr Collect_Len -$Buf_Len
    return
  binary scan [TCP::payload] cS Rec_Type Version
  if { $Version <= 768 } {
    log local0. "stop_ssl3: Rejecting SSL3 or lower connection attempt from [IP::client_addr]"
    reject
    TCP::release
Select Pool Based on Http Payload
https://devcentral.f5.com/s/questions/how-to-select-pool-based-on-http-payload-
This is slick. Sergio is taking post data to select pools. Not sure if this is for a better level of service, or for heightened security screening, but a really useful scenario none the less. The astute among you will notice that there are 22 lines instead of 20. Well, Colin's rules don't count the lines wasted by a single bracket, so I'm just toeing the line here. Take it up with Colin!
if { ([HTTP::method] eq "POST") } {
HTTP::collect [HTTP::header Content-Length]
when HTTP_REQUEST_DATA {
set decoded [decode_uri [HTTP::payload]]
set ini [string first "\"idBiller\"" $decoded]
if { $ini != -1 } {
set end [string first "," $decoded $ini]
set value [string range $decoded $ini [expr {$end-1}]]
set idBiller [lindex [split $value ":"] 1]
switch -exact $idBiller {
11111111 {
pool Pool_XXX
default {
pool Pool_YYY
iRule Environment Variables
https://devcentral.f5.com/s/questions/irule-environment-variables-any
This might be a first, in that there isn't really an iRule featured here. But the concept is important, so I'm breaking rank. Jie asked about environment variables. THi weighed in with one, but here's the comprehensive list of tcl_platform options.
  • $static::tcl_platform(os)
  • $static::tcl_platform(osVersion)
  • $static::tcl_platform(tmmVersion)
  • $static::tcl_platform(byteOrder)
  • $static::tcl_platform(platform)
  • $static::tcl_platform(wordsize)
  • $static::tcl_platform(machine)
  • cpu
Another useful set of commands not directly environment variables but system related are in the TMM namespace.
  • TMM::cmp_cluster_primary
  • TMM::cmp_count
  • TMM::cmp_group
  • TMM::cpm_unit
And that's a wrap! Super powered functionality featured in less than 60 lines of code.
    Comments
    NULL1981_174998
    99999999999.464×(x)+(x)-(x)÷(x)(+x)=99999999999.464 99999999999.464×(b)+(b)÷(b)-(b)=99999999999.464 Microscope, Time Machine, Weather Changer and Youth Laser Possible Formula
    Version history
    Last update:
    ‎22-Oct-2014 14:01
    Updated by:
    Contributors
