on 17-Mar-2015 16:47
Problem this snippet solves:
I’ve been tinkering with a way to allow iRules to make that easier, and to allow those interested parties to see some usage statistics in a visually interesting, real-time manner, without adding much heavy lifting for you or your application. The idea is simple, create a heat map view of your HTTP requests, mapped to the locations around the United States (to start with). This will give you an idea which areas are most highly utilizing your application in a very easy on the eyes fashion. Best of all, of course, is that we’re going to generate this 100% with iRules. For the full write-up check out the Tech Tip
Code :
when HTTP_REQUEST { if {[HTTP::uri] starts_with "/heatmap"} { set chld "" set chd "" foreach state [table keys -subtable states] { append chld $state append chd "[table lookup -subtable states $state]," } set chd [string trimright $chd ","] HTTP::respond 200 content "Here is your site's usage by state: " } elseif {[HTTP::uri] starts_with "/resetmap"} { foreach state [table keys -subtable states] { table delete -subtable states $state } HTTP::respond 200 Content "Reset Map
Table Cleared. Return to Map" } else { set loc [whereis [IP::client_addr] abbrev] if {$loc eq ""} { set ip [expr { int(rand()*255) }].[expr { int(rand()*255) }].[expr { int(rand()*255) }].[expr { int(rand()*255) }] set loc [whereis $ip abbrev] } if {[table incr -subtable states -mustexist $loc] eq ""} { table set -subtable states $loc 1 indefinite indefinite } } }
