hwidjaja_37598
Altostratus
Altostratus
Problem this snippet solves:
A simple perl script that allows you to locate a block contain an element withing bigip.conf
How to use this snippet:
cut and paste this code to a file (eg. /tmp/mygrep.pl) and make sure the executable bit is set (eg. chmod a+x /tmp/mygrep.pl)
Code :
# Script Source
#!/usr/bin/perl
 use strict;
 my ($File, $Pattern) = @ARGV;
 my $buf;
 open (fh, $File) || die "Cant open $File";
 local $/;
 $buf=;
 close (fh);
 while ($buf =~ /([^\n]*\{[^\{]*$Pattern[^\}]*\})/sg){
 print "$1\n---\n";
# SAMPLE
[root@bigip:Active] config # /tmp/mygrep.pl /config/bigip.conf http-xff
 virtual vip1.80 {
     pool vip1.80
     destination aaa.bbb.ccc.ddd:http
     ip protocol tcp
     rules SNAT2VIP
     profiles
        http-xff
        tcp-lan-optimized
           serverside
        tcp-wan-optimized
           clientside
     persist source_addr_30min
  virtual vip-2.80 {
     pool vip-2.80
     destination mmm.nnn.ooo.ppp:http
     ip protocol tcp
     rules SNAT2VIP
     profiles
        http-xff
        tcp-lan-optimized
           serverside
        tcp-wan-optimized
           clientside
 [root@bigip:Active] config # /tmp/mygrep.pl /config/bigip.conf password
 $ ./test.pl h password
 user root {
    password crypt "[cut]"
 user admin {
    description "Admin User"
    group [cut]
    home "[cut]"
    shell "[cut]"
    role administrator in all
 user f5emsvr {
    description "F5 EM Service Account"
    id [cut]
    group [cut]
    home "[cut]"
    shell "[cut]"
    role guest in all
 configsync {
# NOTE: It's not well tested, use it on your own risk and on dev machine first.
Version history
Last update:
‎17-Mar-2015 13:29
Updated by:
Contributors
