Problem this snippet solves:
This iRule makes routing decisions based upon the destination address and whether that address is in on the the data groups called. This uses the matchclass method to try and match IP::localaddr to the members of various data groups. As an aside IP::localaddr is on a forwarding virtual server returns the value of the destination ip address.
Code :
# David A. Homoney, F5 Networks Consulting
# July 2006
# Tested on 9.1.1
when CLIENT_ACCEPTED {
   if { [matchclass [IP::local_addr] equals $::Subnet1] } {
pool FW1
   } elseif { [matchclass [IP::local_addr] equals $::Subnet2] } {
pool FW2
   } elseif { [matchclass [IP::local_addr] equals $::Subnet3] } {
pool FW3
   } elseif { [matchclass [IP::local_addr] equals $::Subnet4] } {
pool FW4
   } elseif { [matchclass [IP::local_addr] equals $::Subnet5] } {
pool FW5
   } elseif { [matchclass [IP::local_addr] equals $::Subnet6] } {
pool FW6
   } elseif { [matchclass [IP::local_addr] equals $::Subnet7] } {
pool FW7_SNAT
   } elseif { [matchclass [IP::local_addr] equals $::Subnet8] } {
pool FW8
      pool FW9
Tested this on version:
9.1
Comments
nomæd
F5 Employee
F5 Employee
What is the actual difference between "equals" and the standard TCL's "eq" for comparing strings?
Version history
Last update:
‎17-Mar-2015 12:38
Updated by:
Contributors
