Hello,
We need to achieve this :
(or whatever url after the “mobile”) redirect/rewrite it to : Parked at Loopia (or whatever url that was entered after the “mobile” in the first place).
Our irule looks like this currently:
when HTTP_REQUEST { if {([string tolower [HTTP::host]] eq “mobile.domain.com”)} { HTTP::respond 301 Location “https://mobile.newdomain.com[HTTP::uri]”
} if {([string tolower [HTTP::uri]] contains “/mobile”)} {HTTP::respond 301 Location ";} }
What happens it when going to : “” it redirects to “mobile.newdomain.com” as it should. But when entering “” it redirects to “Parked at Loopia” Any help would be much appreciated! thank you!
Hi!
Using the pre-formatted option in the forum makes the iRule readable:
set
if { [HTTP::host] eq "mobile.domain.com" } {
HTTP::respond 301 Location "https://mobile.newdomain.com[HTTP::uri]"
if { [string tolower [HTTP::uri]] contains "/mobile" } {
HTTP::respond 301 Location "https://mobile.newdomain.com";
You state in your question that:
Looks like the example needs to be updated?
Another tip is to exampine Chrome developer tools to see where the redirect came from (check the server header). Sometimes requests reaches the application.
Final tip, don’t set up if conditions with a result of a redirect where both can be matched. It could lead to unpredictable results and/or error messages in your logs. Better to use if/elseif.
/Patrik
Try this rule instead (untested for syntax errors)?
} elseif { [string tolower [HTTP::uri]] contains "/mobile" } {
HTTP::respond 301 Location "https://mobile.newdomain.com[string map -nocase { "/mobile" "" } [HTTP::uri] ]";
