I am trying to do a irule redirect for urls. I am trying to trick something for a DR situation. I have a redirect service that is off campus. So for my DR situation I have a closed off network. I trick the DNS with a dns translation on my firewall and point the three different hosts to the same IP on the F5. I created a VIP on that IP and am trying to write and IRule that will redirect based on the URL you think you came from.
So if I goto the dns redirects me to 1.1.1.1 on my F5 I want to redirect that to which is here one of the urls is vip-joe. I wanted to do an if else rewrite but couldn’t get it to work. Tried if { [http::host] contains “darmap”} with a redirect. Really lost and tired. Any help would be greatly appreciated. Thanks Joe
At the end I tried to shorten it to see if I could get anything to work, the last one won’t build so there is a syntax error. If you couldn’t tell already my IRule building starts with devcentral search and try to fit it to what I am doing. Thanks Joe
Hey guys, Thanks so much for your help. The test ended on Friday and I was off yesterday. Unfortunately it ended before I was able to get this working. I was working on a lot of other problems so this could not be my main focus. But I have a base to start with for next test. I think with logging enabled I would be able to find the problem and resolve it.
