devops cloud virtualization Just because you don’t detail the complexity doesn’t mean it isn’t there
It should be noted that this is one – just one – Java EE application and even it is greatly simplified (architectural flowcharts coming from the dev side of the house are extraordinarily complicated, owing to the number of interconnects and integrations required). Most enterprises have multiple applications that require just as many interconnects, with large enterprises numbering their applications in the hundreds.
Related blogs & articles:
- Devops Proverb: Process Practice Makes Perfect
- Devops is a Verb
- 1024 Words: The Devops Butterfly Effect
- Devops is Not All About Automation
- Application Security is a Stack
- Capacity in the Cloud: Concurrency versus Connections
- Ecosystems are Always in Flux
- The Pythagorean Theorem of Operational Risk
