Two-Factor Authentication using YubiKey, YubiCloud and APM
Introduction
What is a YubiKey?
The YubiKey is an innovative USB-key that simplifies the process of logging in with strong two factor authentication. With a simple touch on the device, it gener...
Published Apr 29, 2014
Version 1.0Smithy
cbignon
Dec 03, 2018Hi Brett I use your guide and it works. Thank you. I have a question about yubicloud version. In 2019 yubiko will change it security. there will be a nex URL https://api.yubico.com/wsapi/2.0/verify which seems to need of ID, OTP, and NONCE parameters. Did you test it and can you tell me how to do? thanks for your answer. Regards
