Sessions and Cookies and Persistence, oh my!
At some point (you hope!) it becomes necessary to implement load-balancing for your applications. So you went out and got one, either from a hardware vendor or maybe downloaded a solution, and put it...
Published Jun 04, 2008
Version 1.0Lori_MacVittie
Employee
Joined October 17, 2006
Lori_MacVittie
Employee
May 31, 2014@Sujal,
There are a few reasons why persistence might not work as expected - there's a good discussion of some of them in this thread: https://devcentral.f5.com/questions/cookie-persistence-failure-due-to-client-behavior.
Some basic things to check on would be the timeout value in the profile and to determine whether you're using session or cookie persistence, as they behave differently.
Lori
