iRule: insert cert info into HTTP headers
Here's one that illustrates how to use the "session" command in conjunction with SSL certificate information to allow passing of information to backend webservers.
As above, I want to deliver ssl cert serial number to http server behind BIG-IP, and redirect the users who has no cert to an error page at same time.
After a bit of coaching by unRuleY and Colin, here's what came out.
when CLIENTSSL_CLIENTCERT {
set ssl_stuff [list anything1 anything2]
set ssl_cert [SSL::cert 0]
set ssl_errstr [X509::verify_cert_error_string [SSL::verify_result]]
lset ssl_stuff 0 $ssl_cert
lset ssl_stuff 1 $ssl_errstr
session add ssl [SSL::sessionid] $ssl_stuff 180
set ssl_stuff2 [session lookup ssl [SSL::sessionid]]
set ssl_cert2 [lindex $ssl_stuff2 0]
set ssl_errstr2 [lindex $ssl_stuff2 1]
if { $ssl_errstr2 eq "ok" } {
HTTP::header insert SSLClientCertStatus $ssl_errstr2
HTTP::header insert SSLClientCertSN [X509::serial_number $ssl_cert2]
HTTP::redirect http://192.168.0.64/error.html
Click here for the forum thread.
-Joe
[Listening to: Notes...- Prima Donna - Original Soundtrack - The Phantom Of The Opera (1986 Original London Cast) (10:55)]
Published Aug 10, 2005
Version 1.0No CommentsBe the first to comment
