Agentic AI with F5 BIG-IP v21 using Model Context Protocoland OpenShift
Introduction to Agentic AI
Agentic AI is the capability of extending the Large Language Models (LLM) by means of adding tools. This allows the LLMs to interoperate with functionalities external to the LLM. Examples of these are the capability to search a flight or to push code into github. Agentic AI operates proactively, minimising human intervention and making decisions and adapting to perform complex tasks by using tools, data, and the Internet. This is done by basically giving to the LLM the knowledge of the APIs of github or the flight agency, then the reasoning of the LLM makes use of these APIs. The external (to the LLM) functionality can be run in the local computer or in network MCP servers.
This article focuses in network MCP servers, which fits in the F5 AI Reference Architecture components and the insertion point indicated in green of the shown next:
Introduction to Model Context Protocol
Model Context Protocol (MCP) is a universal connector between LLMs and tools. Without MCP, it is needed that the LLM is programmed to support the different APIs of the different tools. This is not a scalable model because it requires a lot of effort to add all tools for a given LLM and for a tool to support several LLMs. Instead, when using MCP, the LLM (or AI application) and the tool only need to support MCP. Without further coding, the LLM model automatically is able to use any tool that exposes its functionalities through MCP. This is exhibit in the following figure:
LLMs/applications and tools without and with MCP supportMCP example workflow
In the next diagram it is exposed the basic MCP workflow using the LibreChat AI application as example.
The flow is as follows:
- The AI application queries agents (MCP servers) which tools they provide. The agents return a list of the tools, with a description and parameters required.
- When the AI application makes a request to the AI model it includes in the request information about the tools available.
- When the AI model finds out it doesn´t have built-in what it is required to fulfil the request, it makes use of the tools. The tools are accessed through the AI application.
- The AI model composes a result with its local knowledge and the results from the tools.
Out of the workflow above, the most interesting is step 1 which is used to retrieve the information required for the AI model to use the tools. Using the mcpLogger iRule provided in this article later on, we can see the MCP messages exchanged.
Step 1a:
{ "method": "tools/list", "jsonrpc": "2.0", "id": 2 }
Step 1b:
{ "jsonrpc": "2.0", "id": 2, "result": { "tools": [ { "name": "airport_search", "description": "Search for airport codes by name or city.\n\nArgs:\n query: The search term (city name, airport name, or partial code)\n\nReturns:\n List of matching airports with their codes", "inputSchema": { "properties": { "query": { "type": "string" } }, "required": [ "query" ], "type": "object" }, "outputSchema": { "properties": { "result": { "type": "string" } }, "required": [ "result" ], "type": "object", "x-fastmcp-wrap-result": 1 }, "_meta": { "_fastmcp": { "tags": [] } } } ] } }
Note from the above that the AI model only requires a description of the tool in human language and a formal declaration of the input and output parameters. That´s all!. The reasoning of the AI model is what will make good use of the API described through MCP. The AI models will interpret even the error messages. For example, if the AI model miss-interprets the input parameters (typically because of wrong descriptor of the tool), the AI model might correct itself if the error message is descriptive enough and call the tool again with the right parameters.
Of course, the MCP protocol is more than this but the above is necessary to understand the basis of how tools are used by LLM and how the magic works.
F5 BIG-IP and MCP
BIG-IP v21 introduces support for MCP, which is based on JSON-RPC. MCP protocol had several iterations. For IP based communication, initially the transport of the JSON-RPC messages used HTTP+SSE transport (now considered legacy) but this has been completely replaced by Streamable HTTP transport. This later still uses SSE when streaming multiple server messages. Regardless of the MCP version, in the F5 BIG-IP it is just needed to enable the JSON and SSE profiles in the Virtual Server for handling MCP. This is shown next:
Attaching the necessary profiles to the Virtual ServerBy enabling these profiles we automatically get basic protocol validation but more relevantly, we obtain the ability to handle MCP messages with JSON and SSE oriented events and functions. These allows parsing and manipulation of MCP messages but also the capability of doing traffic management (load balancing, rate limiting, etc...).
Next it can be seen the parameters available for these profiles, which allow to limit the size of the various parts of the messages. Defaults are fine for most of the cases:
Profile settingsCheck the next links for information on iRules events and commands available for the JSON and SSE protocols.
MCP and persistence
Session persistence is optional in MCP but when the server indicates an Mcp-Session-Id it is mandatory for the client. MCP servers require persistence when they keep a context (state) for the MCP dialog. This means that the F5 BIG-IP must support handling this Mcp-Session-Id as well and it does by using UIE (Universal) persistence with this header. A sample iRule mcpPersistence is provided in the gitHub repository.
Demo and gitHub repository
The video below demonstrate 3 functionalities using the BIG-IP MCP functionalities, these are:
- Using MCP persistence
- Getting visibility of MCP traffic by logging remotely the JSON-RPC payloads of the request and response messages using High Speed Logging.
- Controlling which tools are allowed or blocked, and logging the allowed/block actions with High Speed Logging.
These functionalities are implemented with iRules available in this GitHub repository and deployed in Red Hat OpenShift using the Container Ingress Services (CIS) controller which automates the deployment of the configuration using Kubernetes resources.
The overall setup is shown next:
In the next embedded video we can see how this is deployed and used.
Conclusion and next steps
F5 BIG-IP v21 introduces support for MCP protocol and thanks to F5 CIS these setups can be automated in your OpenShift cluster using the Kubernetes API. The possibilities of Agentic AI are infinite, thanks to MCP it is possible to extend the LLM models to use any tool easily. The tools can be used to query or execute actions. I suggest to take a look to repositories of MCP servers and realize the endless possibilities of Agentic AI:
- https://mcpservers.org/
- https://www.pulsemcp.com/servers
- https://mcpmarket.com/server
- https://mcp.so/
- https://github.com/punkpeye/awesome-mcp-servers
