Karel_Kohout_51
Oct 18, 2006X-Forward-For
Hello,
is there a possibility on version 4.x to add X-Forwarded-For information to the HTTP header? Can it be done using iRules? Thank you!
Regards
Karel
- hoolio
Hi Karel,
Here is an example from SOL2213: (Click here)
X-Forwarded-For: ${client_addr}
Add this in the pool configuration's "header to insert" field and you should be set.
Aaron
