Grant_Mericle_1's avatar
Grant_Mericle_1
Aug 17, 2017
Where does iCall 'puts' output go to?
I see several iCall examples using the 'puts' command for logging but I can't find where the output goes.
  • Hi,
    "puts" is a tcl command that write string into a channel.
    You can type
    man puts
    it will gives you all info regarding this tcl based command.
    puts ?-nonewline? ?channelId? string
    If no "ChannelID" is specified in arguments, it will print the string to "stdout"
    Check also this
    Hope it helps
    Regards
