dum0785's avatar
dum0785
Icon for Cirrus rankCirrus
Jun 02, 2019
Solved
What's the difference "Virtual Wire" and "VLAN group(Transparent) "
What's the difference "Virtual Wire" and "VLAN group(Transparent) "?
Please tell me easily!
  • I just know difference simply.
    vlan-group can create self-ip.
    and virtual-wire can`t create self-ip.
    that difference cause difference result.
    1) virtual-wire can`t health check.
    -> to do HC, you have to using other interface and considering lots of things.
    2) vlan-group function is basically arp-proxy architecture. transparent was little different.
    -> If your L2 layer knowledge was poor, very hard to trouble shooting.
    3) virtual-wire feature support over i5600.(not correct bigip 5000 series support too.)
    If you have other question, let`s discuss!
  • SWJO's avatar
    SWJO
    • Kalo's avatar
      Kalo
      Hello,
      Do you know whether or not the virtual wire also disable the PVA acceleration automatically(like vlan-group does), if we have confgigured FatL4 virtuals?
      I'm wondering which one has better performance.
  • Thanks, answering.
    Is the meaning the same otherwise?
    Oh, it's OK. I use i2600 this time.
    • SWJO's avatar
      SWJO
      i2600 didn`t support virtual-wire.
      virtual-wire feature support hardware platform over i5000
  • A VLAN group is used to forward traffic between two disparate VLANs, and can have self IP addresses associated with it.
    A virtual-wire can be used to forward traffic between two interfaces, typically both with the same 802.1q tag. According to documentation, not all iSeries platforms support the virtual-wire option.
  • SWJO's avatar
    SWJO
    vlan group and virtual wire are used for transparent topology.
    to use vlan group, have to create 2 vlans. ex) ext int
    -> both ext int vlan is same broadcast-domain.
    -> In normal case, each vlan have different broadcast-domain.
    and create vlan-group with member ext int name VG
    and you can create self-ip with vlan->VG.
    If you consider HA pair, have to consider loop topology.
    And you have to configure exclusive IP address each bigip`s self-ip.
