Georgi__Joe__St's avatar
Georgi__Joe__St
Dec 16, 2015
What is proper way to stop irule processing when F5 is behind Akamai CDN
Hi guys,
I am adapting current iRules to be "compatible" with Akamai CDN. My current challenge is how to replace properly drop, reject or event disable.
Any safe way to close HTTP session and disable irules processing for it, without closing TCP connection?
Currently I am focusing on HTTP::redirect and "if/then" flag that irule need to be skipped.
    if { $HTTP_Request_State eq "Continue" } {
        Do Something
But will be cool if there is other way, for some vhost we have more than 10 rules...
  • Hi Joe,
    instead of using variables to deactivate certain script blocks, you could disable further iRule processing by using
    [event disable all]
    followed by an
    return
    to stop the current iRule. To reenable the events again you have to either
    TCP::close
    the connection or configure an LTM Policy which reenables the iRule processing on each subsequent HTTP request.
    LTM Policy Condition:
    • Every request
    LTM Policy Action:
    • Target: TCL
    • Event: request
    • Action: set-variable
    • Name: dummy_var
    • Expression: [event enable all]
    Cheers, Kai
  • Any HTTP requests routed via Akamai CDN come with "Via" Header that contain 'akamai' sub-string in it. Therefore, for HTTP services you can use my iRule as a starting point. You can similarly just start with the functionality right after the Via header value check, but if you have more bypass conditions, such as some monitoring server IPs, using a variable could make your code look better visually.
    I use similar logic
      set byPass 0
      if  { [HTTP::header value "Via"] contains "akamai" }{
         Replace akamai with llnw if you use Limelight
        set byPass 1
      if  { $byPass == 0 }{
         Do whatever you want here
