What exactly does 'Received Reset' mean
Can someone provide clarification on exactly what 'Received Reset' means under virtual server -> statistics -> Miscellaneous on LTM (v11.5.3)? Did LTM receive a TCP RST? From whom - member or client? We've had Sun LDAP issues since migrating and that field is at the same count as the total connections field and I'm wondering what exactly that means. I can't seem to find a sufficient description in any documentation.
Thanks!
Hello,
This is the number of TCP reset received from the peer for a specific tcp profile. If you use the same tcp profile for client and server side, the statistics for each side are mixed.
