What does replace-all-with command does in tmsh??
for example : --
tmsh modify sys snmp traps replace-all-with { b4566b { version 1 community fgfhfkn6 !RR host "hgjghgjj" } }"
- Hannes_Rapp
Hi. This will remove all existing snmp traps, and replace with the new one(s) you define inside curly braces. Using the option "add" in place of "replace-all-with" will retain existing snmp traps, and append the ones you define inside curly braces.
- BJ_114988
Thanks hanns!!
- Hannes_Rapp_162
Nacreous
- BJ_114988
Thanks hanns!!
