Subrun's avatar
Subrun
Feb 29, 2020
Warning while running tmsh load sys config verify
Hello , I ran "tmsh load sys config verify" before code upgrade of an HA having LTM, APM , ASM running on it.
No idea about 2 warning shown below. How to fix it before Code Upgrade ? Or with this Warning can I still proceed for Code upgrade ?
Validating configuration...
 /config/bigip_base.conf
 /config/bigip_user.conf
 /config/bigip.conf
 /config/bigip_script.conf
There were warnings:
/Common/SSl-Debug:28: warning: [The following errors were not caught before. Please correct the script in order to avoid future disruption. "unexpected end of arguments;expected argument spec:PROC_SCRIPT"1592 798][proc flowid-gen {
       # Find the name of this Virtual Server, minus the partition/path.
       # Use these for the short VIP name
       set vipsplit "[split "[virtual name]" /]"
       set vipname "[lindex $vipsplit end]"
       # Use this instead for the VIP name including partition path
       #set vipname [virtual name]
       # Start an event counter
       set eventnum 1
       # Mark the start time and create a unique ID for this flow
       set flowtime "[clock clicks]"
       set flowid "slot[TMM::cmp_group]/tmm[TMM::cmp_unit]-$flowtime"
# this return left in iffy state due to no proc calls from flow_init experimentation
       return "$vipname $flowid $flowtime $eventnum"
/Common/SSl-Debug:137: warning: [The following errors were not caught before. Please correct the script in order to avoid future disruption. "unexpected end of arguments;expected argument spec:PROC_SCRIPT"10855 57][proc test {
       log -noname "test happened!"
In profile access (/Common/ActiveSync_App.app/exch), duplicate log destination (/Common/local-db) is found with configured publishers (/Common/sys-db-access-publisher) and (/Common/sys-db-access-publisher).
In profile access (/Common/ActiveSync_App.app/exch), duplicate log destination (/Common/local-syslog) is found with configured publishers (/Common/sys-db-access-publisher) and (/Common/sys-db-access-publisher).
In profile access (/Common/OutlookWebAccess_App.app/exch), duplicate log destination (/Common/local-db) is found with configured publishers (/Common/sys-db-access-publisher) and (/Common/sys-db-access-publisher).
In profile access (/Common/OutlookWebAccess_App.app/exch), duplicate log destination (/Common/local-syslog) is found with configured publishers (/Common/sys-db-access-publisher) and (/Common/sys-db-access-publisher).
  • From my experience you can just ignore the 'duplicate log destination' warnings.
    Regarding the iRule, why not store it offline (notepad) and delete it before you do the upgrade as it seems to be a debug iRule anyway. You can add it again after the upgrade if needed.
  • Subrun's avatar
    Subrun
    Thank You for your reply, But does it say which iRule it is ? I do not see whats the iRule name here I should Look for.
  • Just in case anyone else stumbles upon this question in the future like I have, the warning "unexpected end of arguments;expected argument spec:PROC_SCRIPT" is caused because proc is looking for a name for the arguments after the procedure name.
    This will cause a warning:
    proc test {
    This will not:
    proc test args {
    You don't even have to use the argument in the proc.  Just having it named, in this case args, will stop the warning from happening.
