WAM Disabling for a application module doesn't work
if { ([HTTP::uri] contains "movil") } {
WAM::disable
CACHE::disable
when HTTP_RESPONSE {
if { [HTTP::header "Location"] contains "movil" } {
WAM::disable
HTTP::close
CACHE::disable
The when i use the cache::disable option in v11 throws me the error by the LTM log TCL error: Operation not supported (line 1) invoked from within "CACHE::disable"
When i see this i try to remove the sentence, but after that the application doesn't work. The execution of the iRule goes with problem but WAM is not disabled. :( Please Help Me
- tdk_51797Historic F5 AccountIf you have a VS with WAM on it, you don't need (and can't invoke) CACHE::disable. So drop the two CACHE::disable lines, and you should be good to go. Hope that helps. :-)
