idcf5's avatar
idcf5
7 months ago
WAF Policy upload using AS3
I am using per-app declaration to upload multiple WAF policies in an app. when I post the declaration using POST command, i only get 202 accepted, and in the backend, the F5 uploads the ASM policies. How can I get to know iff all the policies are uploaded successfully or if any have failed? Is there any command or rest api?
POST : https:/<f5ip>/mgmt/shared/appsvcs/declare/Demo/applications
    "id": "per-app-declaration",
    "schemaVersion": "3.54.2",
    "controls": {
        "class": "Controls",
        "logLevel": "debug",
        "trace": true
    "WMS_ASM": {
        "class": "Application",
        "template": "generic",
        "wms_Dispatcher_asm_v172": {
            "class": "WAF_Policy",
            "file": "/var/tmp/v17/wms_Dispatcher_asm_file.xml"
        "wms_MessageStoreAPI_asm_v172": {
            "file": "/var/tmp/v17/wms_MessageStoreAPI_asm_file.xml"
        "wms_abdg_asm_v172": {
            "file": "/var/tmp/v17/wms_abdg_asm_file.xml"
        "wms_auth_asm_v173": {
            "file": "/var/tmp/v17/wms_auth_asm_file.xml"
        "wms_carrier-info_asm_v172": {
            "file": "/var/tmp/v17/wms_carrier-info_asm_file.xml"
        "wms_cas_asm_v172": {
            "file": "/var/tmp/v17/wms_cas_asm_file.xml"
        "wms_csdui_asm_v172": {
            "file": "/var/tmp/v17/wms_csdui_asm_file.xml"
        "wms_csrkodiak_asm_v172": {
            "file": "/var/tmp/v17/wms_csrkodiak_asm_file.xml"
        "wms_getContactAddlInfo_asm_v172": {
            "file": "/var/tmp/v17/wms_getContactAddlInfo_asm_file.xml"
        "wms_keymanagement_asm_v174": {
            "file": "/var/tmp/v17/wms_keymanagement_asm_file.xml"
        "wms_kodiakidsprov_asm_v172": {
            "file": "/var/tmp/v17/wms_kodiakidsprov_asm_file.xml"
        "wms_lcms_asm_v173": {
            "file": "/var/tmp/v17/wms_lcms_asm_file.xml"
        "wms_mcsxcap_asm_v173": {
            "file": "/var/tmp/v17/wms_mcsxcap_asm_file.xml"
        "wms_mobileapi_asm_v172": {
            "file": "/var/tmp/v17/wms_mobileapi_asm_file.xml"
        "wms_ngcat_asm_v172": {
            "file": "/var/tmp/v17/wms_ngcat_asm_file.xml"
        "wms_oidcxcap_asm_v172": {
            "file": "/var/tmp/v17/wms_oidcxcap_asm_file.xml"
        "wms_tpams_asm_v172": {
            "file": "/var/tmp/v17/wms_tpams_asm_file.xml"
        "wms_wcsr_asm_v172": {
            "file": "/var/tmp/v17/wms_wcsr_asm_file.xml"
        "wms_webdispatcher_asm_v172": {
            "file": "/var/tmp/v17/wms_webdispatcher_asm_file.xml"
