VS HTTPS and Pool HTTP
Please, i am new with F5.
I need do a VIP (VS) on port 443, and the hosts on pool are on port 80, how could i do this ?
Tks
- Lee_Payne_53457
You just need to create the pool members as http inside a https VS and make sure you have the VS doing SSL offloading.
- Kevin_Stewart
Employee
If I may add, the port translation option in the virtual server's configuration is what allows this to work. This is set by default on a standard virtual server. As Lapayne says, create a pool of port 80 servers and apply a client SSL profile to the virtual to offload SSL.
- Lee_Payne_53457
Here is a good guide on configuring VS's, it's version 10 but the principles are the same.
http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm_configuration_guide_10_0_0/ltm_virtual.html
