Kristian_Petter's avatar
Kristian_Petter
Apr 04, 2017
VPN solution where local administrator is not required.
I'm looking for a VPN solution that does not require user / client is local admin. This is intended for example for consultants at a client who is not a local administrator on their computers.
I wonder if this works, if one avoids setting up a Layer 3 VPN Tunnel with eg F5 APM?
My thought is to set up a portal where I publish RDP links to the terminal servers that the consultants should have access to. I hope I can use one two factor solution with F5, where the customer has a proprietary SMS solution.
Do you know any guidance on how to implement this?
I am grateful for every answer.
  • Hi,
    with F5 APM, you can use 2 different solutions:
    • Remote desktop resource within a "Full Webtop". it will display a portal with all assigned resources (Internal web sites, RDP resources, Citrix resources, ...)
    • Remote desktop gateway to access RDP servers directly with MSTSC client
      mstsc client --HTTPS--> F5 APM as RDP Gateway --RDP--> Internal server
    Full webtop can use multiple authentication protocols.
    Remote desktop gateway only support NTLM authentication
