TPI_144811
Oct 03, 2014VLAN Group and AFM
My customer need to implement the AFM in bridge mode by using VLAN GROUP. So Do we have to concern any point about the AFM with the Vlan group?
- Arnaud_Lemaire
Employee
Assuming you are running 11.4.0 or above, and that it is not a VE it should work pretty easily.
remember that if you are using vlan tagging you will need to have a different tag between internal and external vlan on the big-ip, that is how vlan-group are working.
- TPI_144811
Thanks for your advice.
