O__Nilssen's avatar
O__Nilssen
Oct 12, 2021
Virtual and pool current connections differs a lot, is it normal?
The virtual prod_https_vs is using the pool prod_https_pool, the current connections quantities is far from the same. What may be the explanation for this?
show ltm virtual prod_https_vs
Current Connections           4.9K
show ltm pool prod_https_pool
Current Connections           751
  • Then the results that you are seeing are normal. Due to oneconnect profile, exiting idle connections gets reused while sending request to the pool member. So the new server-side connection won't be initiated with pool member if the existing idle connection is available for reuse for other client requests.
