Sli_85735
Jul 20, 2015Viprion 2400 _ running 2 X 2250 Blades
Hi All,
I have a few questions;I am currently running 2 2250 Blades in 2400 Viprion Chassis and they are currently in an active cluster and Blade 1 is master and Blade 2 is "standby".
- Can I run 2 separate environments with this design, basically have Blade1 run APP1 only and Blade 2 run APP2 only?
- Is it possible to break the cluster between 2 blades in 1 Chassis?
- Is it possible to have 2 blades in 1 chassis exist as standalone ( no fail-over between blades)
Thanks in advance.
i believe this mainly depends on how you got this configured, with vCMP you can do a lot of what you want, are you using that?
- Sli_85735
Thanks Boneyard.. Yes I am currently using vCMP.
how are your vCMP guest configured, screenshot please.
