VIP using two different URL and certificates
I have a scenario that the server team is asking to create a VS in the F5 that will be used by an external application to access an internal application using API. But in the scenario, there are some points to be considered.
1) the external application will use a specific URL and certificate https://url1.domain.com that will be configured in the F5 (VS Standard, Client SSL Profile and etc.)
2) the internal application is configured to use another URL and certificate https://url2.domain.com.
I will create a client SSL profile using the external certificate and a Server SSL Profile using the internal certificate.
In that case, I need to use an iRule to rewrite the HTTP Location on the HTTP header to match the same URL that is used by the internal application? I am not considering using a redirect.
Regards,
TM
Hi Thiago,
I understand that you have one external hostname for your app and one internal. In your example url1.domain.com for external and url2.domain.com for internal.
And that you have different paths for internal and external. External might be /dirA/index.html, while internal might be /dirB/index.html.
So for users accessing the app via url1.domain.com you want to rewrite the HTTP::host and (partially) the HTTP:path so that they match the internal ones, right? That can be done with iRules or with LTM Traffic Policies. I find this picture handy to learn the terminology.
For the SSL bridging, 90% of the cases can be satisfied with the default serverssl profile, it is sufficient to establish a connection to a pool member using https. Unless you have requirements on the serverside, like SNI or SSL protocol, this serverssl profile will do.
Best of luck
Daniel
- Thiago_Morais
Altostratus
Hi Daniel,
Thank you for your reply.
I got more details about the request that the application will handle.
External URL: https://url1.domain.com:10002/coreService/services
Internal URL: https://url2.domain.com:10002/coreService/services
In that case, I am thinking to use an iRule to rewrite the HTTP::host from url1.domain.com to url2.domain.com in the HTTP_REQUEST and HTTP_RESPONSE?
What do you think about it?
Regards,
TM
Hi Thiago,
I would use a LTM Traffic Policy instead on an iRule and also I would pay attention if maybe you want to rewrite the Referer header too.
In a Traffic Policy you would do it like this (tmsh output)
ltm policy policy_route_url1.domain.com { controls { forwarding server-ssl } requires { http } rules { match_url1.domain.com { actions { 0 { http-host replace value url2.domain.com } 1 { http-referer replace value "tcl:[regsub -nocase {url1.domain.com} [HTTP::header Referer] {url2.domain.com}]" } 2 { forward select pool pool_url2.domain.com } } conditions { 0 { http-host host values { url1.domain.com } } } } status published strategy first-match }KR
Daniel
