VIP configuration appears in CLI mode but not in GUI mode
We have a F5 virtual edition configured on a blade server. We are currently facing a very wierd problem with only one VIP. The VIP configuration when displayed in CLI shows correctly, but does not appear in the GUI mode.
- nitass
Employee
have you seen it in configuration file i.e. /config/bigip.conf? if yes, i think you had better open a support case.
- swapnil_89332
Check if you have configured partitions other than Common. If yes, the VIP in the other partition will not be visible in Common partition but you can view it in CLI. To see the partitions, see on the top right corner of the main page and you will find a dropdown tab, click on it to see if any other partition is configured. Select that partition and you can view the VIPs under it.
Thanks Swapnil
