Vertica DB Monitoring Failure post upgrade 10.x to 23.x
I need assistance with a Vertica monitor, due to versions have caused the F5 to no longer be able to use a postgresql monitor.
-Why does the monitor for 23.3 no longer work?
Pool Monitor
Type: Postgresql
local login: password verified and working for version 10.1
Current Vertica Version: 23.3 / Previous Version 10.1
*TMOS 15.1 and 17.1 have the same Pool member status result/symptoms
Monitors tested: Postgresql, Oracle, Mysql ( to think outside the box )
Currently configured for the Pool: Postgresql
-Send strings tested for all monitor types-
Send String: SELECT 1
Send String: SELECT 1 FROM DUAL;
Receive: 1 *10.1 = Success / 23.3 Fail
Receive: Nothing *10.1 = Success / 23.3 Fail
Both Select 1 and Select from Dual receive the below successfully
_________________________________________________________________________________________________
Troubleshooting via F5 CLI
foo.bar.f5.com:Active# DB_monitor cmd status debug
Telnet Port 5433 = Successful
Version of jdbc does not matter between TMOS versions, the monitor still fails
RPM version ( TMOS 15.1 )
postgresql-jdbc-42.2.13-.0.0.32.noarch
postgresql-9.3.2-0.0.32.i686
postgresql-libs-9.3.2-0.0.32.i686
postgresql-share-9.3.2-0.0.32.i686
RPM version ( 17.1 )
postgresql-server-15.0-1.fc38.0.0.2.x86_64
postgresql-jdbc-42.2.13-0.0.2.noarch
postgresql-private-libs-15.0-1.fc38.0.0.2.i686
postgresql-15.0-1.fc38.0.0.2.x86_64
postgresql-private-libs-15.0-1.fc38.0.0.2.x86_64
- ShaunSimmons
Altostratus
Bump - Buller...Buelller..Bueller 🤣
- ShaunSimmons
Altostratus
Anyone have any thoughts? :)
Do you also have a ticket open with F5 support? That seems like the good way to go.
