Jonathan_Scholi's avatar
Jonathan_Scholi
Oct 15, 2012
Version 11.2 synchronize_to_group_v2 problem
When I try to use the 11.2 method synchronize_to_group_v2 as follows:
configSyncStub.synchronize_to_group_v2("/Common/sync", "", true);
I get the error:
System::urn:iControl:System/ConfigSync::synchronize_to_group_v2()
Exception: Common::OperationFailed
primary_error_code : 16908342 (0x01020036)
secondary_error_code : 0
error_string : The local device was not found
Why would the local device not be found?
  • John_Gruber_432's avatar
    John_Gruber_432
    Historic F5 Account
    Make sure you are in the /Common folder. The local device doesn't exist in /, but it does in /Common. If this is your problem, there is already a ticket open requesting the iControl be fixed to understand this and not require the iControl user to figure this out.
