Nath's avatar
Nath
Jan 15, 2018
vCMP and Viprion systems in HA
Hi Experts,
Just want to know if we can setup vCMP and Viprion systems in HA. Example I have 2 Viprion Chassis, 1 is vCMP enabled(Chassis1) and 1 is Viprion LTM(Chassis2).
Is it possible that we will configure the LTM guest of Chassis1 together with Viprion LTM in HA?
Ty
  • Hamish's avatar
    Hamish
    You want to do async HA?
    It should work, but pretty sure it's notofficially supported (You may want to check that out with your support contract - it never used to be supported, but been while since I wanted to do anything similar so may have changed... or not... Note that in the links provided state F5 recommend identical hardware [hardware parity] on both sides)
    As above (In the links provided by Youssef) you can see that connection mirroring more than likely won't work.
