VCenter SSO configuration for load balancing
Hi, I am doing configuration VCenter SSO as per below guide. "VMware® vCenter Server™ 5.5 Deploying a Centralized VMware vCenter™ Single Sign-On™ Server with a Network Load Balancer" But at VMware end facing some issue, please find the below logs which is getting in VMware end :-
2015-11-12T17:26:46.323+03:00 [01336 info 'Default'] Initializing SSL 2015-11-12T17:26:46.323+03:00 [02868 info 'ThreadPool'] Thread enlisted 2015-11-12T17:26:46.323+03:00 [01336 info 'Default'] Vmacore::InitSSL: handshakeTimeoutUs = 120000000 2015-11-12T17:26:46.323+03:00 [01964 info 'ThreadPool'] Thread enlisted 2015-11-12T17:26:46.339+03:00 [01336 info 'Default'] Starting VMware VirtualCenter 5.5.0 build-2646482 2015-11-12T17:26:46.339+03:00 [01336 info 'Default'] Log directory: C:\ProgramData\VMware\VMware VirtualCenter\Logs.
--> * A certificate in the host's chain is based on an untrusted root. --> --> * self signed certificate in certificate chain) 2015-11-12T17:26:48.277+03:00 [01336 error '[SSO][SsoFactory_CreateFacade]'] Unable to create SSO facade: SSL Exception: Verification parameters: --> PeerThumbprint: 72:D4:1F:3C:5E:E7:62:3D:69:6E:21:84:79:A7:2E:AE:7C:A5:DF:5C --> ExpectedThumbprint: --> ExpectedPeerName: pmcrbvaaolbs01.ads.xyz.edu.sa --> The remote host certificate has these problems:
Can you please help me on this issue?
- Kevin_Davies_40
Nacreous
Possibly this is your issue? "A certificate in the host's chain is based on an untrusted root. --> --> * self signed certificate in certificate chain"
